Head Gasket Bore
Old Jan 11, 2019 | 03:34 PM
racerguy's Avatar
Default Head Gasket Bore
I have a stock b18c that is bored to 82mm. I was curious as to whether the OEM head gasket would work with this bore size.
Old Jan 11, 2019 | 06:06 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: Head Gasket Bore
i wouldn’t think you would want a gasket to over hang into the cylinder, I would recommend getting a 82mm gasket
Old Jan 11, 2019 | 07:12 PM
Aradin's Avatar
Premium Member
You don't want too much overhang because it can act like a hot spot and cause preignition and detonation under some circumstances. With that said, being only 1mm over on a stock engine, you should be fine.
Old Jan 12, 2019 | 02:17 PM
civic-steve-94's Avatar
I'm pretty sure that the OEM gasket is designed to work up to 82MM bore. So that the dealer can service the engine up to 82MM.
Old Jan 12, 2019 | 09:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The factory "B" series head gasket is .50mm larger than the stock bore. Specifically, B16A, B18A/B, and B18C1/5 OEM head gaskets are bored at 81.5mm and the B20B/Z OEM head gaskets are bored at 84.5mm.
It is never a good idea to have gasket material hanging out into the combustion chamber... meaning the block bore is LARGER than the gasket cylinder opening. The offending material gets red hot during operation and promotes detonation/pre-ignition and increases the chances of blowing a head gasket. It is always best to use a gasket that is the same size as the cylinder bore or slightly larger... as in .5mm larger at most.
Eghatchgsr8
Sep 19, 2014 02:24 PM
nychonda
Jun 4, 2011 07:42 PM
riceball777
May 17, 2004 07:10 PM
jt-sport
11
Feb 11, 2004 02:57 PM
schwett
Apr 18, 2002 04:19 PM
