Speedo issues
Old Jan 11, 2019 | 01:52 PM
Joey Mitchell's Avatar
Default Speedo issues
I'm having an issue with my speedometer where it will start randomly jumping around sometimes at higher speeds like between 60 and 80 mph. It only does it for a few seconds then goes back to acting normal .The car is a 98 ex sedan. And ideas??? Thanks!
Old Jan 11, 2019 | 02:29 PM
One92Eg6's Avatar
Default Re: Speedo issues
it could be that your speed sensor is failing. check that, it sits on the back side of your trans.
Old Jan 11, 2019 | 03:51 PM
muellersfan's Avatar
Post the CEL codes and check dash fuse 15.
Old Jan 11, 2019 | 04:12 PM
chrysler kid's Avatar
Most common issue is connector at the sensor on the transmission has a short or corrosion on the actual pin in the connector
If there is no check engine light and the connector is clean the speedometer could be having issues
If the check engine light is on the ecu can not see the signal. You would need to post the trouble code
If 3 codes for oxygen sensor 1 and 2 and vehicle speed sensor are present then fuse 15 in the lower dash panel is blown
roxics
10
Mar 1, 2013 12:37 PM
anduhy
Jan 16, 2008 11:17 AM
brentaction22
May 24, 2007 09:28 PM
tpod
17
Mar 1, 2006 12:41 PM
Chicano
May 8, 2005 08:43 PM
