HELP! Setting Blackworks Coilover
Old Jan 11, 2019 | 07:07 AM
kris29's Avatar
Default HELP! Setting Blackworks Coilover
hello
I am being installed coilover for my delsol and I find that the low is still very high, I wonder if it is the right reference? someone has already installed is coilover? how to settle them? thank you in advance
Old Jan 11, 2019 | 07:22 AM
White_EG1's Avatar
Default Re: HELP! Setting Blackworks Coilover
You needed to set height before you installed the coil overs.
You’re gonna have to unbolt the strut fork, loosen the bottom ring, and spin the bottom of the coil over until you see it move more up towards the threads.
Old Jan 11, 2019 | 07:29 AM
kris29's Avatar
Hello, thank you for your answer, I have already settled this part I went up the lower part to the highest towards the spring
Old Jan 11, 2019 | 07:54 AM
NVturbo's Avatar
O.G. triple O.G.
because...Blackworks
Blackworks is overpriced Ebay brand...just like Function+Form, Yonaka, Godspeed, EMUSA, blah, blah blah...
Old Jan 11, 2019 | 08:20 AM
kris29's Avatar
yes I agree but I would like to understand, other possibility they are not compatible delsol ...
Old Jan 11, 2019 | 09:16 AM
tony_2018's Avatar
Fish Twig
If they didn't give you a wrench to adjust those rings you best call them about that. Suppose to be 2 of them.
Old Jan 11, 2019 | 09:54 AM
kris29's Avatar
yes I have two I already change the tension of the spring before it was even higher as if I was original! someone told me that they may be models for EK or Integra?
Old Jan 11, 2019 | 10:20 AM
tony_2018's Avatar
Fish Twig
Why not ask the manufacture on how to identify what coilovers you got and go from there?
Old Jan 11, 2019 | 11:41 AM
NVturbo's Avatar
O.G. triple O.G.
The 2 upper perch locks are to tighten the springs SNUGLY. They are not meant to adjust height. Take a measurement of the existing height and take note. Loosen the lower SINGLE perch and spin it upwards. Rotate the bottom shock body into the threaded upper shock portion by how much you want to lower the car.
IT'S NOT THAT DIFFICULT.
Old Jan 11, 2019 | 12:08 PM
kris29's Avatar
I understand but I'm already at the end
Old Jan 11, 2019 | 02:37 PM
One92Eg6's Avatar
you've got to drop this perch lower.
Old Jan 11, 2019 | 07:24 PM
tony_2018's Avatar
Fish Twig
You didn't lower them...they're still up there.
Old Jan 12, 2019 | 12:11 AM
kris29's Avatar
yes in this photo to show that I was in maximum for the reglagle of the height, the reglagle of the spring has been modified since (compression at minimum), which gives the finall the height of the first photo
Old Jan 12, 2019 | 02:47 AM
tony_2018's Avatar
Fish Twig
Mmk. Sure thing but your 2nd image says it all.
Old Jan 12, 2019 | 04:09 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You've bottomed out on the tube.
In order to go lower, droop the spring by lowering the preload collars but be aware that you will wear the strut faster and blow it out if you go too low.
Have fun ruining your car and spine. I don't miss the days of trying to get as low as possible
Old Jan 12, 2019 | 04:10 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Pay closer attention to his pic
Old Jan 12, 2019 | 04:21 AM
kris29's Avatar
compared to the tension of the spring? I can not go down anymore! it will not be in tension, I do not ask a question for the back I may be so low that I can put the car on the ground, there has not been a reversal of shock absorbers, not springs
Old Jan 12, 2019 | 04:27 AM
tony_2018's Avatar
Fish Twig
I see a good decent amount of thread to still lower the spring, One92Eg6 has an image and explains what I'm saying. But if he can't lower it any more, and that is the max it can lower than there is nothing you can do other than cut the spring which can be dangerous. SIMPLE.
Old Jan 12, 2019 | 04:37 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
His issue is that I can't drop the body lower. That's the point he's trying to get across.
But yes, if he droops the spring itself, he can lower the vehicle more.
Old Jan 12, 2019 | 04:39 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
How much lower do you want to go?
The last thing you can do is remove the locking collar for the Spring collars, and lock the spring collar to the height body collar. That is the absolute maximum you can go, safely.
Old Jan 12, 2019 | 04:41 AM
tony_2018's Avatar
Fish Twig
the heck you need to drop the strut down more for, silly lowering attention.. go find a coilover with short strut body. All thats going to do is make the ride even more stiff.
Old Jan 12, 2019 | 04:59 AM
kris29's Avatar
I would like to be able to go down to the level of the wing board, if I go down the wheel spring it will float, at the back I have no problem, sorry for the translation
Old Jan 12, 2019 | 05:10 AM
tony_2018's Avatar
Fish Twig
that would be the max you can go if you the manufacture can't tell you how to do that.
Old Jan 12, 2019 | 07:26 AM
kris29's Avatar
but first of all I would like to know if I have the right coilover for delsol otherwise I have sold it for good
=lefthere is the result at the lowest for the front:
Old Jan 12, 2019 | 09:01 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
How is this website supposed to answer THAT question? That's a question for the manufacturer!
