Where can I buy this
Old Jan 6, 2019 | 03:01 PM
89ED's Avatar
Default Where can I buy this
i called some part stores all I can give them is it has five sides
I’m cleaning out the iacv. Of course y’all willl day I don’t even hav to take it out that’s just my luck
Old Jan 6, 2019 | 04:31 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Where can I buy this
You could see if you can locate a penta security bit set and see if any of the 5 lobe bits fits and grabs well in that fastener.
Something like these on Amazon.com:
Amazon Amazon
Old Jan 7, 2019 | 09:44 AM
hondamark35's Avatar
it's not made this way on accident. it requires a specialty bit because it is supremely difficult to set properly outside of factory conditions/equipment. if it's causing you trouble, you're not likely to fix it by removing this screw.
with that out of the way...
in a large mixing bowl add a cheap file and bench vice. mix carefully while pouring in spare/orphaned hex keys until one works. enjoy responsibly.
Old Jan 7, 2019 | 03:16 PM
89ED's Avatar
I made one at my local smog shop from a piece like the other. The owner asked me why I’m doing that. I replied to clean it out my car doesn’t want to idle. He replied “put a hole it a vacuum line and it will raise the idle” lol what a joker. He then said why don’t you just push out that pin lol I’ll post a pic I think has right tho
Old Jan 7, 2019 | 04:17 PM
89ED's Avatar
so I don’t know wtf I’m doing I ripped out the screen bc it doesn’t pop or slide out lol
89ED's Avatar
And that pin I mentioned doesn’t come out lol
Old Jan 7, 2019 | 05:11 PM
tony_2018's Avatar
Fish Twig
Ah, I recall some dude taking his iacv completely apart. Been a while and I don't think it was posted on HT but he was able to do it. I just don't have the time, gotta prioritize other things.
Old Jan 8, 2019 | 06:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I believe that spring and penta bolt is set as a special penta bolt due to the spring tension being calibrated at factory. Now that you have removed it, it's very unlikely you will be able to obtain the same tension that was set at factory.
Best of luck to you.
MattZ28
May 3, 2007 11:07 AM
_BEN_
Welding / Fabrication
Jan 23, 2007 11:15 AM
EgSalad
Dec 3, 2004 09:26 PM
Jared
Jul 22, 2004 08:43 PM
N24RE
10
Nov 7, 2002 05:41 PM
