Tps help!!
Old Jan 4, 2019 | 09:10 PM
fear45's Avatar
Default Tps help!!
From my understanding im suppose to have an open throttle near 5v and a closed throttle near .5v however,after using a multimeter
.43v = opened throttle
2.53v = closed throltle
is the tps bad?and why does closed seem closer to the 5v and opened seem closer to the .5v
(d15b2 dual point)
Old Jan 5, 2019 | 04:11 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Tps help!!
What wires are you probing?
Post a picture of the order of the wires on the TPS connector.
Old Jan 5, 2019 | 01:10 PM
fear45's Avatar
used red middle wire and battery ground
Old Jan 5, 2019 | 02:49 PM
muellersfan's Avatar
First make sure the TPS is installed correctly.
If fine:
The Grn/Wht wire is ground.
The Yel/Wht is reference voltage (5V).
The middle Red/Blu wire is signal to the ECU.
If you use the Grn/Wht wire as ground, what are the closed and WOT voltage readings on the Red/Blu wire?
If you use the Grn/Wht wire as ground, do you read 5V on the Yel/Wht wire?
Old Jan 6, 2019 | 10:57 AM
fear45's Avatar
Using the grn/wht as ground and yel/wht as 5v i checked the voltage and got 4.98v The tps closed is .43v and WOT 4.05v using the red wire and grn/wht.
Throttle continues to get stuck whenever i slightly give throttle or whenever i press and hold the gas peddle for a second or two. After tapping on the gas peddle the throttle settles back down to idle.
Old Jan 6, 2019 | 11:36 AM
Adjust the TPS to 0.5V when TB plate is closed.
Also clean the TB.
Old Jan 7, 2019 | 06:27 AM
4drEF's Avatar
Keyboard Humorist
lube the cable too.
Old Jan 8, 2019 | 12:26 PM
~sp33~'s Avatar
EFB055
And clean the return spring.
mecca858
Apr 25, 2022 09:12 AM
giddyup21
Mar 18, 2012 06:49 PM
LaMaravilla
Sep 18, 2010 12:28 AM
ej6.sean
11
Oct 7, 2009 06:01 PM
