Honda CR-V & Element 2WD & 4WD Element & CR-V
2011 CRV-SE VTC Actuator noise on Startup - This year not in TSB?
Old Jan 3, 2019 | 09:10 AM
philw12's Avatar
Default 2011 CRV-SE VTC Actuator noise on Startup - This year not in TSB?
I have a 2011 CRV-SE 2WD that has the same VTC Actuator noise at cold startup that many others have had. I have downloaded and read the latest TSB for this problem (09-010) and I noticed that the 2011 CRV's are not included in this. Only 08-12 Accords and 2012-2013 CRV's are.
Plus, under further investigation, the new "repaired" VTC Actuator part (14310-R5A-305) that is specified in this TSB is a different part number than what is required for my car (The 2011 CRV needs 14310-R40-A02).
I am not able to find any other TSB's that include the 2011 CRV's for this same issue. What I am worried about is replacing my VTC Actuator with a new VTC Actuator part (14310-R40-A02) and it does not fix the problem.
Has anyone done this repair on a 2010 or 2011 CRV and had success??
Does anyone know if the 14310-R40-A02 part has been changed to fix the cold noise startup?
Thanks
Golfnut
Jun 26, 2013 08:38 AM
wxy117
Mar 24, 2008 10:26 PM
makri
Feb 3, 2006 09:03 AM
krings
Feb 17, 2003 12:16 PM
btr24evr
Feb 3, 2003 07:51 AM
