Headlight wiring
Old Jan 1, 2019 | 07:39 PM
russ donnan's Avatar
Default Headlight wiring
I bought a universal 3 wire headlight socket to wire driver side headlight but I'm at a loss on how to hook it up
Old Jan 1, 2019 | 08:37 PM
muellersfan's Avatar
Default Re: Headlight wiring
Car?
Old Jan 2, 2019 | 04:45 PM
avisitor's Avatar
Three wire is usually for double filament bulbs
Look at bulb
The two filaments have a common lead
That lead is for ground
The two others are for power to each filament
Before replacing, look at old wiring and how bulb goes in
This should help clear things up
Note: Should make sure wring has good contacts
Having a gap or bad solder or butt connector will cause resistance and burn out of wiring
Old Jan 2, 2019 | 05:24 PM
Look at bulb
With car information, one can tell OP how to connect the stock wires to provide headlight functions as intended by Honda.
Old Jan 10, 2019 | 01:32 PM
avisitor's Avatar
With what car information? Owner's manual?
How to connect wires to a headlight socket only takes a little understanding of how electricity works and how a circuit functions
It isn't rocket science and doesn't require a degree from the college of Honda cars ... hahaha
Old Jan 10, 2019 | 02:42 PM
Exactly
Old Jan 10, 2019 | 03:05 PM
mk378's Avatar
For example I think the 1996 and later apply power to the common wire and switch between high and low by grounding one of the other wires.
Old Jan 10, 2019 | 03:29 PM
tony_2018's Avatar
Fish Twig
lol////
Old Jan 10, 2019 | 03:50 PM
Originally Posted by tony_2018
lol////
Exactly
Old Jan 11, 2019 | 03:33 AM
NVturbo's Avatar
O.G. triple O.G.
pay someone to work on your car OP
Old Jan 11, 2019 | 10:28 AM
avisitor's Avatar
Can find out by using multi-meter and get readings off the wires
No need to guess.
Old Jan 11, 2019 | 10:34 AM
No need to guess.
Old Jan 11, 2019 | 11:37 AM
NVturbo's Avatar
O.G. triple O.G.
No need to guess.
I doubt OP even know what model car he is driving/owns/working on. That's not going to help the cause.
Old Jan 12, 2019 | 05:49 AM
avisitor's Avatar
Every one rises to their level of incompetence .... lol
jasoncanseeoh
Feb 9, 2010 02:20 PM
sageuvagony
Oct 4, 2008 09:07 PM
Red_Si
Apr 17, 2008 05:01 PM
jdmbb6
Nov 15, 2004 05:34 PM
IVANITR
Sep 1, 2001 07:13 PM
