Mini me oil weight
/\ nailed it. oil capacity is for the block, so use the same. 5w30 is standard honda oil for engines of this vintage. warmer climates can use 10w30. did you remember to pull the oil jet from the block?
Yes I did, and I figured it would be the same, just didn't know if the higher compression or some factor unknown to me would require or do better with a different weight. Thanks guys
srv3fender
Mar 21, 2005 05:08 AM
