need to bore??
Old Nov 13, 2002 | 07:49 PM
1RMDave's Avatar
Default need to bore??
i just got an ls block and it has about 140,000 miles on it. i want to use my pr3 pistons in it and aside from regular wear after that kind of milage it doesn't seem to have any problems. i was wondering if i can just hone it and use new rings or should i bore it out and get different pistons?
Old Nov 13, 2002 | 09:21 PM
1QUICKEF's Avatar
Default Re: need to bore?? (OneStunna)
hone it if you bore it then u need to buy oversized pistons but its all up to u
Old Nov 14, 2002 | 09:10 AM
94CivicSi's Avatar
Default Re: need to bore?? (1QUICKEF)
you're going to have to mic the cylinder walls to know for sure. If the pistons have worn a taper into the cylinder walls, you're going to have to bore it. A good manual will show you how to take readings properly and what the minium variance should be.
Old Nov 14, 2002 | 11:56 AM
Kataku2K3's Avatar
Default Re: need to bore?? (94CivicSi)
For having 140,000 miles i would just overbore .25mm then go with oversized PR3's... Nice clean cylinder walls to work with..
Old Nov 14, 2002 | 01:28 PM
builthatch's Avatar
MiG-21 superfan
Default Re: need to bore?? (JDMspecEG6)
bruck mic'ing, just overbore .050 and get .050 over pistons.
[Modified by builthatch, 5:28 PM 11/14/2002]
aznpreludeSH
Feb 20, 2005 09:38 AM
AgentJam
Jul 22, 2004 06:22 PM
ZERO COOL
Mar 1, 2003 09:23 AM
ITRbroham
Feb 18, 2003 06:11 AM
p10hlm
Jan 7, 2003 11:25 PM
