Lifter Taping sound... shall i ignore it ?
Old Dec 26, 2018 | 05:24 PM
Tie Ee Fei's Avatar
Default Lifter Taping sound... shall i ignore it ?
My B20B With B16 (small Vtec) started to have annoying taping sound...
but the engine run great..
So Questions is it ok to ignore it ? was planning saving more money for the rear disc-brake conversions / and manual..
Or i shall change it ASAP ?
Fyi i using 10w/40 for my motor ~~
Old Dec 26, 2018 | 06:08 PM
muellersfan's Avatar
Default Re: Lifter Taping sound... shall i ignore it ?
No lifters
Use engine stethoscope to pinpoint noise.
Old Dec 26, 2018 | 06:20 PM
Tie Ee Fei's Avatar
Originally Posted by muellersfan
No lifters
Is not my injectors too..
The valve leash ok too.. So that is the only thing i can think of..
Old Dec 26, 2018 | 06:33 PM
GhostAccord's Avatar
No lifters
You are correct that there are no lifters. These engines are OHC so they do not have lifters or rods that require valve lash. But you could have said that they do have valve tappets can and do make noise if the they are out of adjustment (kind of like valve lash).
OP, is the noise coming from the head or the block, only when it's warm or all the time?
and why 10w40?
Old Dec 26, 2018 | 07:27 PM
Understood, but seemed premature prior to knowing location of noise source.
Old Dec 29, 2018 | 12:38 AM
Tie Ee Fei's Avatar
some times it happen more is the engine is warm...
but even is cold is still there...
and why 10w40 ? i have no idea the pervious onwer are using this. so i guess i just continue
Old Dec 29, 2018 | 11:41 PM
eghatch9295's Avatar
Stancetard Hate Monger
10w40 is a heavy oil, not ideal for your application. it is possible the previous owner was using to mask oil consumption issues, quiet a knock, or both. if it is knocking, don't ignore it... stop driving it. like now.
Old Dec 30, 2018 | 01:04 AM
Tie Ee Fei's Avatar
Thanks for the reply.. Is not knocking sound is only like tap tap tap.. From the head.. Any recommand oil for my engine?
joshmak
Jun 13, 2010 10:07 AM
b20integrapower
Honda S2000
17
Feb 25, 2007 02:42 PM
ednyboo
Jan 6, 2007 10:23 AM
SIRBUSH
Oct 31, 2002 09:43 PM
BryanS
Sep 25, 2001 10:46 AM
