EF Sedan with D16z6 smokes on 1st start up HELP
Old Dec 26, 2018 | 11:02 AM
ZoKe's Avatar
Default EF Sedan with D16z6 smokes on 1st start up HELP
Hi Honda tech been a lurker for a while now but finally have a problem i cannot seem to find a solution to online.
I have a 1990 Dx Sedan that i dropped a semi built D16z6 (Rods, pistions, Springs) into and ive run across a few issues. I had some trouble starting the car but i added a ground from the thermostat to the frame and she started right up. Im running a HA Motorsprorts Obd0 MPFI to Obd1 jumper and i convertered the DPFI harness to MPFI myself. There are 2 problems im having. The 1st is that i seem to have high voltage to my TPS sensor which is inhibiting me from properly calibrating it. I Have 4.5v at idle and like 8v WOT. The reference wire is even like 8v. The 2nd issue im having is when i start the car and let it run IT SMOKES BAD. I know a little smoke is normal from assembly as well as i cranked the engine with no plugs in so it probably got some extra oil in places it usually doesn't but doesn't appear to be pure oil either, i did make sure to window all the rings when assembling the engine. It smells of fuel bad so i believe its just running extremely rich, i pulled the plugs and they appear to be a little wet from fuel. The mechanical timing is spot on and i have yet to set the ignition timing with a gun but even when i just move the dizzy back and forth i get no change. Im going to get the ignition timing done today and hope that changes something a little. Im really lost but i think all my troubles are electrical related and i just dont know where yo start diagnostics.
ANY HELP IS GREATLY APPRECIATED 😬
Old Dec 26, 2018 | 01:17 PM
muellersfan's Avatar
Default Re: EF Sedan with D16z6 smokes on 1st start up HELP
To what ECU pin does the 8V TPS wire run? What color is the wire?
Post all CEL codes thrown.
Old Dec 28, 2018 | 09:36 AM
ZoKe's Avatar
its throwing a code 7 and code 9. I havent checked the voltage at the ecu pins ill check that tonight. The wire i believe is red/white. I know i have the correct wires tho i just cant remember the colors. I did a little more looking around and took my exhaust manifold off and there is a bunch of fluid in all for exhaust ports. I believe its fuel mixed with some oil. The does appear to be running extremely rich.
Old Dec 28, 2018 | 06:08 PM
ZoKe's Avatar
Update i found that my oil was contaminated bad with fuel. As well as there is mixture of oil/fuel sitting on my pistions when i look into my spark plug holes. Would this mean was oil ring as well as running rich?
Old Dec 28, 2018 | 06:11 PM
stampern22's Avatar
What color is the smoke? white, blueish white, black?
Old Dec 28, 2018 | 06:12 PM
ZoKe's Avatar
The car is throwing a code 7 and 9. I will check voltage at the ecu pin and get back to you. I did switch the wires on the tps sensor for the MPFI swap. The wire colors are green/white red/blue and yellow/white.
Old Dec 28, 2018 | 06:13 PM
ZoKe's Avatar
It appears to be blueish white and it doesn't dissaper quick it lingers
Old Dec 28, 2018 | 06:15 PM
ZoKe's Avatar
Also this same fuel/oil mixture is in all 4 exhaust ports
Old Dec 28, 2018 | 06:18 PM
stampern22's Avatar
Blueish white is oil burning, but that doesn't mean that's the issue, and could just be a symptom of something else going on. I'd say start with the mpfi wiring, both codes relate back to that wiring and go from there.
Old Dec 28, 2018 | 06:22 PM
You also need to fix code 9 (distributor sensor), which will make the engine run like crap or not at all.
Old Dec 28, 2018 | 06:29 PM
ZoKe's Avatar
That would mean just a whole new dizzy correct?
Old Dec 28, 2018 | 06:30 PM
ZoKe's Avatar
I think im just gonna remake a whole new harness lol im a little unhappy with how long i made some wires etc .
Old Dec 28, 2018 | 06:31 PM
Could also be a bad wire or ECU.
Ohm test the distributor sensor first. If bad, replace distributor.
If good, test the two sensor wires. Then go from there.
Old Dec 28, 2018 | 06:41 PM
ZoKe's Avatar
Got it i will check that tomorrow morning and go from there!
Old Dec 30, 2018 | 05:58 PM
ZoKe's Avatar
Update.
i decided to make another engine harness and sure enough my high voltage problem was solved and i was able to calibrate my TPS sensor. Not sure what i did wrong on the other one but at this point i really dont care lol. The car is now throwing a code 6 (Engine coolent Temp Sensor) which it could be the plug is worn or frayed because i didnt have the code with the other harness. The car is still smoking bad unfortunately. It seems as though it is still a fuel issue. When i look in the sparkplug holes i can see fuel just chillin on the pistons. I know that the ECTS dictates how much fuel the ECU sends so im going to attempt to fix that code tomorrow. The code 7 and 9 are gone now so atleast i accomplished something 😬
Shadowcat
16
Nov 28, 2014 02:20 PM
dohcdelsol
Jul 27, 2008 07:21 PM
opelorc
Nov 13, 2007 09:53 AM
opelorc
Nov 12, 2007 03:48 PM
AronJarl
Apr 20, 2006 03:32 PM
