Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine bolt into timing co er
Old Dec 26, 2018 | 10:10 AM
LI-HONDAGUY's Avatar
Default Engine bolt into timing co er
I broke my timing belt with on 30k on it only,replac it two years ago. The engine bracket behind the timing cover , ( the bolt ) came out. Will that hit the belt or make the engine shift to hit the belt and brake?
Old Dec 27, 2018 | 05:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Engine bolt into timing co er
No loose bolts should be inside the timing cover... they will either get caught between the belt and gears and make the engine jump time or cut/break the timing belt. You can try using an extendable magnet to get the bolt out if you can see it... otherwise, you will have to remove the covers to get it out.
Good luck.
Old Dec 28, 2018 | 01:49 PM
The front engine mount bolt loosens up and back out. Will the threaded end of the bolt hit the belt if it backs out ? This is the bolt that you can get too on the front of the timing cover.
Old Dec 28, 2018 | 04:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the bolt you are referring to is visible from outside of the timing cover, it will not cause any issues at all with timing if it falls out... assuming you have ALL of the timing covers installed. It MAY cause trouble with the A/C and alternator belt or possibly the P/S belt, but this possible damage is small compared to what a bolt can do inside the timing cover. If it is loosening and backing out on it's own, something is wrong. You should investigate further. Loc-Tite is not normally used for these bolts... so it should be a last resort fix.
Jimster480
Nov 11, 2010 08:04 AM
lsvteg11
Aug 20, 2009 10:32 AM
methos713
May 5, 2008 08:01 PM
MI4$DC5
Feb 22, 2006 05:28 PM
hatchinprogress
10
Jul 14, 2005 04:46 PM
