Soaking wet passenger floor
I have a 2003 civic LX with 80,000 miles and the passenger floor is soaking wet, it’s water not coolant. When I google it some people say it’s the a/c drain hose but I cannot find the hose in my car. Has anyone had this issue or can give me some advice? The a/c blows cold air and the heat works perfect.
If you can't find the hose then you've found your problem. On the 2003 it's still at the passenger's feet but it will be under a cover if your car still has it. I believe it comes off with some push tabs, then you pull it out. At the very back and bottom of the evaporator housing you'll at least see a fitting where a hose hooks onto. It's supposed to go through the firewall and down to drain.
If it's still there, it's likely clogged. If it's gone, go to a junkyard and find one or put some generic hose on it.
