Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Stock rear toe adjustment? 1st gen
Old Dec 23, 2018 | 08:18 AM
B_Swapped93's Avatar
Default Stock rear toe adjustment? 1st gen
As far as I can see there's no stock/factory rear toe adjustment on the CL9? unless i'm missing something. I assume one has to go and buy the Hardrace kit(4 arms total), as soon as you use an adjustable upper control arm in the rear you can see the toe is out of spec.
Old Dec 26, 2018 | 12:12 PM
Ryanthegreat1's Avatar
Default Re: Stock rear toe adjustment? 1st gen
The rear control arm has an eccentric bolt on the body side for adjusting toe.
Old Jan 7, 2019 | 05:10 PM
I saw that once I decided to remove all the multi-link arms, wouldn't have provided adequate toe adjustment at my current ride height. Decided to get the 4pc toe/lateral arm set from hard race and the rear upper control arm aka camber kit as well.
e.p
Sep 13, 2016 10:41 AM
scheibler
Apr 22, 2016 10:20 PM
mrboompow
Suspension & Brakes
Oct 8, 2013 08:29 AM
SKDRCR
Jan 8, 2010 05:27 PM
ESCALVANTE
11
Mar 12, 2002 06:17 PM
