What would cause a no CEL condition.
Engine was swapped from an F22B2 to a F23A. Original ECU (OBD1) and wiring harness. Key in ignition, I get SRS light, brake light, seatbelt light, headlights and radio works but no Check Engine Light.
Any kind of help is much appreciated. I don't get the battery light either.
Are you sure the lights were not blown before the swap? Verify they are not blown.
Does the fuel pump prime?
Sounds like it could be a missing or bad ground. Did you ensure to hook the main ground back up to the intake manifold? The main ground is G101, located at the end of the upper intake manifold on the lower vacuum header bolt.
by GhostAccord, on Flickr
djmnc
Nov 17, 2006 03:37 AM
