Diagnostic help needed: 1990 CRX b16a2 swap - Radiator issue
1990 CRX b16a2 swap. Radiator fan quit working on me and I'm not sure what happened. I jumped the coolant temp switch and still nothing. I am getting 12v all the way to the fan but apparently my ground isn't functioning. When I pull the ground wire from the fan and hook it straight to a body ground the fan fires right up but stays running constantly until I turn the key back off. Where should I start? Fuse is good, swapped relays, jumped temp switch already and nothing. Where does this ground go to?
Do you have a schematic of the radiator fan or control of radiator fan?
Is the control box on the power side or ground side.
Assuming it is ground side switched, would look for a control box or module
Sometimes on-line parts sites will have a diagram of the components they sell as they would sit in the vehicle
Just a suggestion
Just a suggestion
If the relay is fine, continuity test the Blu and Blk wires.
Nameless Warrior
Dec 14, 2006 06:44 PM
Linh.
32
Dec 18, 2005 11:21 AM
