Troubleshooting: B-series Vibration issue
Old Dec 19, 2018 | 08:02 AM
Babar Firasat's Avatar
Default Troubleshooting: B-series Vibration issue
I have an honda civic type r ek with b16a2. When I bought the car, it was fine. I changed the induction kit on it, k&n, and exhaust manifold from 4-2-1 to 4-1, I changed exhaust gasket with it. Added more ground wires. After that the car has been showing problems.
So the car started to loose power all of a sudden when driving and the power would come back, even in vtec, same thing would happen, sudden loss and regain of power. Then one day, one cylinder stopped working. Some of the valves were burnt off. Mechanic changed 4 valves, timing belt, tensioner, water pump, spark plugs. He checked distributor, it's not that.
2 weeks later of getting it, same thing is happening, sudden loss of power with vibration. What could it be?
Old Dec 20, 2018 | 03:15 PM
TheShodan's Avatar
Moderator
Default Re: B16a2 vibrating problem.
Those came with the B16B engine. Not the B16A2. You'll need to be in the Tech/Misc section for this issue. Not the Engine management area.
Old Dec 20, 2018 | 03:21 PM
Yh the engine was once swapped out.
Old Dec 22, 2018 | 12:01 PM
muellersfan's Avatar
Default Re: Troubleshooting: B-series Vibration issue
Honda or aftermarket distributor?
Old Dec 24, 2018 | 02:40 AM
Honda original distributor.
keithdgallagher
Oct 21, 2013 12:02 PM
KeFish
Nov 18, 2012 05:25 PM
cdrift
Dec 17, 2008 08:03 PM
revmoose
Jul 9, 2007 07:58 PM
