Needing help 93 civic with d16y7
This is what I'm working with and considering how little I know about engines I'm proud of myself lol.i put a y7 in my 93 civic it's been 2 months of trial and error.i thought I had my idle issue figured out after swapping to y8 mani (after putting 3 wrong manis on) I think ive got everything close to correct and it was purring when I drove it 800 miles from TN to tx (ballsy test drive I know)no issues tho.ntho.now the idle issue is back.im thinking the iacv is bad but heres a few pics of the chaos.i know my hoses are not right so any advice is appreciated!
Last edited by Cody C; Dec 19, 2018 at 06:27 AM. Reason: Having trouble posting pictures
no light :-/ yes I cleaned the iacv I also ordered a brand new one yesterday just incase.i have 2 different ecu"s the one that came with the 93 civic and one I bought from a friend that told me I needed it "got it cheap so....lol" the difference in the two is it runs rough and idle drops low after pushing the gas in neutral with original edu.one I bought it revs right it only idles up and down while in neutral and when the clutch is pressed.im going to replace throttle body gasket and see if that helps.i have 2 throttle body's one has a green 3 prong plug on the bottom and one does not.not sure wich one is the correct one though.id post pics if I could!
With a little research I now know I have 2 iacv.one on the bottom of the TB and back upper left mani.my harness only has 2 prong the iacv on the TB is 3 prong.do I need to replace my harness plug to fit or do I have the wrong tb for this setup.im sorta new to all this :-/ I'm trying though
would the y8 TB be on the p2p pit-4 mani? It doesnt have the green iacv on it just 2 hose connections where the iacv is on the current tb I have on.my harness already has the 2 prong.2 of them actually.im assuming one goes to the little 'purge valve's nd the other the iacv on top the mani.the TV gasket covers half the hole to the iacv is this the wrong gasket?
I messed with the distributor it seemed to help when postitioned just right but it's gotta be the iacv it revs up n down in shorter spurts fairly quickly
I think I got it figured out.i changed the TB it seems to have leveled out the idle almost completely.itl slightly rev slowly and gets low to a slight putter and eventually levels out.this is my first build il get it figured out.thanks everyone
chicklet
16
Apr 26, 2016 10:02 PM
LtFerris
Mar 2, 2014 07:07 PM
nkcalvert09
Apr 25, 2011 06:48 PM
