Replace Slave Cylinder with Master Cylinder?
Old Dec 18, 2018 | 07:51 PM
Jon Petersen's Avatar
Default Replace Slave Cylinder with Master Cylinder?
Hey all. I'm going to replace my clutch master cylinder as it is leaking out under the pedal. I had a thought -- since it's so easy to replace the slave cylinder, should I replace it at the same time as I replace my master cylinder, as a kind of preventative maintenance? I'd like your opinions.
Thanks.
Old Dec 18, 2018 | 08:24 PM
Chrisfrom1986's Avatar
Default Re: Replace Slave Cylinder with Master Cylinder?
Its cheap enough to do it for the sake of having both parts new. Make sure you flush everything with clean fluid.
Old Dec 18, 2018 | 09:12 PM
jdmark1's Avatar
Definitely. And chances are, if the MC needs to be replaced then the slave is on its way out too. And as always, bleed it and adjust the pedal freeplay after you install
Old Dec 19, 2018 | 11:40 AM
NVturbo's Avatar
O.G. triple O.G.
bench bleed the MC prior to install or you'll never get all the air bubbles out
Old Dec 21, 2018 | 01:43 AM
tony_2018's Avatar
Fish Twig
Old Dec 21, 2018 | 06:16 AM
ppizzo's Avatar
I just did both last weekend. No need to spill brake fluid everywhere twice.
Old Dec 22, 2018 | 08:51 AM
bleed the new MC before I install? Or bleed the old MC before I take it out?
Old Dec 22, 2018 | 12:25 PM
Old Dec 23, 2018 | 02:47 AM
NVturbo's Avatar
O.G. triple O.G.
Bleed whenever you're bored.
djkurious
May 19, 2009 04:22 PM
hawtsoss
Oct 24, 2008 07:21 AM
GSR-TRBO-DA
Nov 26, 2007 08:19 AM
shadohconspiracy
13
Sep 27, 2007 10:09 PM
Zulu888
Jun 19, 2006 09:30 PM
