Car stalled, now starter won’t engage
Old Dec 18, 2018 | 01:30 PM
JJ Mendez's Avatar
Default Car stalled, now starter won’t engage
So the other day I was driving my 99 si, b16 motor and tranny, and I down shifted pretty bad. Car jumped but didn’t stall but afterwards my check engine light came on. Dumb decision but I drove it for about another 4 days and it drive fine, no gear slipping. It did make a slight whining noise when I accelerated in low gears, and I was driving it on the freeway and I got onto the off ramp and it stalled when I pressed my clutch in. And since then it won’t start. I can hear the starter spinning but the motor isn’t turning over. Any ideas? I haven’t checked the codes yet but I’m thinking it’s my flywheel/flex plate? Not 100% sure but I need to get back to work so quick responses are appreciated, thanks
Old Dec 18, 2018 | 01:46 PM
tony_2018's Avatar
Fish Twig
Default Re: Car stalled, now starter won’t engage
Whats the CEL?
Hows your timing belt?
Old Dec 18, 2018 | 06:20 PM
mk378's Avatar
Does the pulley on the end of the engine turn when you turn the starter on? Then take the oil cap off and see if the rocker arms go up and down.
Manual cars don't have a flex plate.
Old Dec 18, 2018 | 07:53 PM
JJ Mendez's Avatar
min going to be removing the valve cover tomorrow in the morning to check the timing belt. I’ll check the codes too and update yall
Old Dec 18, 2018 | 08:51 PM
avisitor's Avatar
Take oil filler cap off and shine a light into valve cover
Have a friend crank engine and watch for movement
No movement means the timing belt could be broken
Needs further investigation
Or taken wrench or socket and turn accessory pulley to see if engine will turn or if it is locked up
Old Dec 19, 2018 | 09:26 AM
tony_2018's Avatar
Fish Twig
Why not just rotate the crank by hand with a torque wrench and a proper socket size?
Old Dec 19, 2018 | 12:27 PM
JJ Mendez's Avatar
just took the valve cover off and the rocker arms look fine and the timing belt is fine. Haven’t checked codes yet but I’m kinda at a loss now. Any further suggestions?
Old Dec 20, 2018 | 05:13 AM
mk378's Avatar
"Looks good" isn't enough, you need to check that the cams actually rotate and are in time. Timing belts usually fail by having the teeth strip off where they engage the crank sprocket. You won't be able to see that with a visual inspection from above.
Old Dec 20, 2018 | 11:24 AM
JJ Mendez's Avatar
so I took a wrench to the crank and it turns fine. Not sure what else to look for. I’ll see if I can get to the pullies later today
skidattle
Feb 1, 2013 06:52 PM
jerryp777
Apr 20, 2010 11:37 PM
eazye5591
Dec 12, 2003 10:22 AM
del_parker
Oct 25, 2003 08:06 AM
