Quick coolant question
Old Dec 13, 2018 | 08:27 PM
Sentree's Avatar
Default Quick coolant question
I recently had to adjust the clamp on my upper radiator hose for my Del Sol. When I did so I had some coolant leak and therefore I added a bit of distilled water to make up for the loss. The timing belt for my car was replaced a few months ago so the coolant is relatively new. My question is, will the added distilled water cause corrosion or any other problems? I'd say I've added about 5-6 cups of distilled water. Should I drain and refill?
Old Dec 14, 2018 | 02:39 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Quick coolant question
You're supposed to add distilled water with the coolant anyways (if it's not the pre-mix stuff). Keep an eye on the temperature gauge to see if it has changed. If not, don't sweat it.
SpoonIntegra808
Oct 21, 2004 05:04 AM
rated_r
May 12, 2004 07:45 PM
Nizzy
Feb 10, 2003 01:05 PM
Andrew Sites
Oct 7, 2001 08:36 PM
Rory Breaker
Aug 23, 2001 09:04 PM
