Troubleshooting: 1997 Civic - fuel pump not priming when electrics are started
Old Dec 13, 2018 | 05:38 AM
rastakid's Avatar
Default Troubleshooting: 1997 Civic - fuel pump not priming when electrics are started
hello team, i have civic 1997 model.
1st my water pipe burst, the one from the radiator to the thermostat housing, fixed that, then my fan wouldn't go on, changed the fuse in the engine bay fuse box, after that the fuel pump was priming anymore..
i have checked the relay on the side of the dashboard.
when ii put the ignition on ii hear it clicking..
i checked the ECU fuse in the engine bay fuse box. and the fuel pump fuse under the dash. both are still perfect.
i tried checking the ground cable from the thermostat housing, but it looks like the wires are soldered together, i have not checked the fuel pump, as ii dont believe the fuel pump could suddenly be the issue, ny other advise and things ii could check??
help would really be appreciated..
Old Dec 13, 2018 | 11:11 AM
rastakid's Avatar
Default re: Troubleshooting: 1997 Civic - fuel pump not priming when electrics are started
i have just checked the fuel pump directly to the battery, and the pump goes on, not sure what else ii can check guys.??
Old Dec 17, 2018 | 06:16 PM
muellersfan's Avatar
Unplug the main relay.
Turn key to ON(II).
In the connector, jump pin 7 to pin 4. Does the fuel pump run?
Jump pin 5 to pin 4. Does the fuel pump run?
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
m.glisson003
Oct 31, 2011 05:53 PM
adicam
Jan 19, 2009 03:59 AM
