Clutch Fluid Leak
Hello all! I have a 95 Civic EX. I've noticed a very slow clutch fluid loss, and I finally located it underneath the clutch pedal inside the car. The area underneath the clutch master cylinder piston is nice and moist with clutch fluid. I'm not too worried about it since it's a very slow leak, however I would like to deal with it eventually. Have any of you dealt with this? Is it an easy fix?
Also, I can post pictures if you like, my phone's camera just isn't very good. Thanks for the help.
I just replaced the clutch master cylinder in my wife's 97 Accord last weekend. Not a Civic, but it was a fairly straight forward replacement. I was having the same issue - couldn't find where the clutch fluid was going, and found the dark spot on the carpet under the pedals. It took about 90 minutes to swap in a new one, including bleeding down. It is kind of a small work space, but there is room to do it. I imagine the Civic would be similar.
cowgirly
Sep 29, 2015 02:21 AM
EliteCivicX
May 18, 2009 03:04 PM
