Clutch Hydraulic Fluid Location???
Just recently my clutch has started to lose pressure, however its still engaging at the right time. It leads me to believe it could be a leak or just lack of fluid in the hydraulic system linked to the clutch.
I have a 97 hatch with a gsr, i was wondering if anyone could direct where to look for this reservoir. If you have any additional information, that would rock! thanks
Re: Clutch Hydraulic Fluid Location???
The clutch fluid reservoir is to the immediate right of the brake fluid reservoir in your picture.
Check for a leak from the master cylinder near the firewall and above the clutch pedal, as well as at the slave cylinder located straight down from the distributor.
hondaless
04-02-2009 08:58 AM
afropuffs808
05-02-2008 06:17 AM
