how much does alignment cost?
its time to get new tires, mounted, i haven't had a chance to do alignment before, stupid me i know, how much does it normally cost to mount tires, and do alignment? say at sears or something? thanks
Sears
I got new tires mounted, balanced and a four wheel alignment with cambers kits installed for about $400 for everything....it was at a local tire shop called 1st Chance Tire in LaVergne TN....
Grant
Grant
An alignment will cost about 60-80 bux. INSIST INSIST INSIST that they set your TOE to exactly ZERO. -1 degree of camber is ideal for better handling. -1.5 or -2 would be even better. But if you like to drag race... -1 is a good middle ground and 0 is best for all out traction.
averyvm
Suspension & Brakes
Nov 2, 2009 10:32 PM
