OEM-like Front Coil spring options? Fitment?
I have an 89 Civic Hatch Si and I'm looking to replace the current Wal-Mart brand coil-over lowering kit garbage with some OEM type struts and springs. I've found everything I need except the front coil springs. PartsGeek has some - but they are specified as fitting Base, DX and LX models.
Would they fit an Si model as well? I tried searching =\
A little googling found the thread linked below, which claims the springs are the same. I question that since Honda lists different part numbers for SIs (discontinued of course). I'm pretty confident DX springs would work, but suspect SI's might be a little shorter and/or stiffer. Hopefully @Tyson will see this, bet he knows.
https://honda-tech.com/forums/honda-...tions-2151605/
If you want close to OEM but a little lower, Tein STechs are really nice and not too expensive.
I have a set of H&R Sport springs I'd let go for cheap but they were too harsh for me.
D16SohcVtec
Mar 21, 2009 05:59 PM
Mr.HondaAccord
Sep 18, 2004 03:41 PM
