No compression in one cylinder
I have a 2004 CRV. I have no compression in one cylinder (2nd left to right). The rest have over 165. I checked if block have some cracks and it doesn't. I checked if head seal/gasket have damage and it doesn't. I don't think its the cylinder, in that case the other cylinders would have similar wear/damage. I guess its the valves. What you think?
This is the CRX/EF Civic section, so first suggestion would be to post this inquiry in the correct subforum for your vehicle.
To save you some time though, you'll probably be directed to do a leak-down test on the bad cylinder. This should help determine where you're losing compression. Once that's done the CR-V guys hopefully can help you out. Good luck.
K24 might have a chain but yea that sounds likely.
stir_fry_boy
May 15, 2018 06:27 AM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
imgonnalie2u
Jan 11, 2005 08:05 AM
