Parasitic draw while running killing car
Old Nov 30, 2018 | 09:01 PM
Chris Schmidt's Avatar
Default Parasitic draw draining while running. Help
I have a 2000 Honda Civic Ex coupe with a D16z6 swap, the car uses the first notch of the headlights to active the cluster as well. I can drive the car almost all day and when it got dark I switched on the headlights and within about half hour I was dead on the side of the road. I’ve already tried doing a parasitic draw test and I found out that the door lock fuse and ac condenser fan was drawing power away but when I replaced them the door locks still continued to take power so I left it unplugged entirely hoping it would help but no succes. If anyone has any info on a common way people may splice into the ignition that would be great or pictures and diagrams of where wires go so I can correct the cut up mess. I’m mainly looking for the wiring digram for everything around the steering wheel and driver door.
Old Dec 1, 2018 | 07:30 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Parasitic draw while running killing car
there's a LOOSE GROUND wire somewhere. Keep looking....
bpenner
Honda Civic (2001 - 2005)
Jun 25, 2018 03:53 PM
user456101
Jun 30, 2016 11:53 AM
jermo
Mar 11, 2011 09:41 AM
samprince
10
Apr 8, 2009 06:44 PM
artob
Feb 20, 2008 05:21 PM
