Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
2012 Ruckus No Start Conundrum
Old Nov 29, 2018 | 08:18 PM
kkevin22's Avatar
Default 2012 Ruckus No Start Conundrum
video of whats going on.
2012 Ruckus wont start. Turns over with starter button but does not fire. Pulling throttle changes the sound but does nothing. Doesn't matter how long this goes on for, still doesn't want to fire up. Kick starter does not start it up either. Any ideas?
-Confirmed getting fuel- pulled fuel line its flowing.
-Confirmed getting spark- pulled plug, grounded, sparks when turning over.
-Cleaned carb and jets
-Reset ECU
-Kill switch in correct position
-Brake lever is down
-fuses are all intact
Replaced:
New battery
New gas tank
New gas
New fuel filter
New fuel pump
New spark plug
Any ideas or next steps?
Thanks all!
Old Dec 30, 2018 | 06:40 AM
sTol2m's Avatar
Default Re: 2012 Ruckus No Start Conundrum
Problem could be electrical, check your ground wires for solid connections.
Possible the ECU is faulty? (it controls the kill switch functions)
Old Mar 10, 2019 | 08:10 PM
kkevin22's Avatar
Thanks! Turns out I didn't clean the carb well enough or it was so gummed up so bad it wouldn't unclog when i wire cleaned it. Replaced the carb and it runs well! Thanks for the info!
Old Apr 18, 2019 | 11:34 AM
amgballer's Avatar
jets
Old Jun 20, 2019 | 11:28 AM
rchid's Avatar
how did you reset your ECU?
biker jim
29
Aug 22, 2019 12:52 PM
Hondsolo
17
May 20, 2018 04:06 AM
ninjaturtleEG
Sep 14, 2016 11:15 AM
jmflyd
19
Aug 13, 2009 07:58 AM
.Noah Fecks
11
Aug 9, 2003 08:06 PM
