2012 Ruckus No Start Conundrum
2012 Ruckus wont start. Turns over with starter button but does not fire. Pulling throttle changes the sound but does nothing. Doesn't matter how long this goes on for, still doesn't want to fire up. Kick starter does not start it up either. Any ideas? -Confirmed getting fuel- pulled fuel line its flowing. -Confirmed getting spark- pulled plug, grounded, sparks when turning over. -Cleaned carb and jets -Reset ECU -Kill switch in correct position -Brake lever is down -fuses are all intact Replaced: New battery New gas tank New gas New fuel filter New fuel pump New spark plug Any ideas or next steps? Thanks all! |
Re: 2012 Ruckus No Start Conundrum
Problem could be electrical, check your ground wires for solid connections.
Possible the ECU is faulty? (it controls the kill switch functions) |
Thanks! Turns out I didn't clean the carb well enough or it was so gummed up so bad it wouldn't unclog when i wire cleaned it. Replaced the carb and it runs well! Thanks for the info!
jets
how did you reset your ECU?
