Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2013 Civic Ex won't start. No lights (power), battery fine. Halp!
Old Nov 29, 2018 | 05:18 PM
BB6Driver's Avatar
Default 2013 Civic Ex won't start. No lights (power), battery fine. Halp!
Mom dukes Civic won't start.
  • No power at all- key fobs don't unlock doors, lights don't go on, no chimes, no aux, nothing.
  • Tried to jump - no luck. Battery tested good.
  • Plucked out the two large fuses in the bay. They're fine. Pulled every 5, 10, 15, and 20 A fuse under the hood and under the dash - all fine
  • Replaced key fob battery, but figured that wouldn't help.
What should I try next? The car is in good shape. Low miles (<25k), always taken care of.
Is there a magical relay that will solve my problem? How are relays easily tested without a volt meter? Could it be anti-theft somehow?
I've never had a car that wouldn't start lose power completely and I've never had a push button start- so I'm used to hearing the starter click, or hearing it try to turn over.
Thanks in advance
Old Dec 1, 2018 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2013 Civic Ex won't start. No lights (power), battery fine. Halp!
Main bus fuse or damage to either the positive or negative battery cables.
Old Dec 1, 2018 | 08:30 PM
avisitor's Avatar
First thing to do is to check the terminal of the battery
Then to clean out the terminal and grounding strap
Make sure the chassis ground is okay.
chloe_m
Honda Civic (2001 - 2005)
Oct 30, 2017 04:54 PM
SSMatey
Apr 19, 2015 05:25 AM
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
wingback44
Nov 14, 2006 03:28 PM
Civic138
Nov 14, 2003 09:51 AM
