96 honda civic radio not working
Old Nov 28, 2018 | 11:02 AM
b&j's Avatar
b&j
Default 96 honda civic radio not working
I just recently bought a 96 honda civic ex and when i got it it had the stock radio in it but it did not have a face so there really wasnt a way to check and see if it actually worked. so i took it out and went to put a JVC in it and its not turning on at all. I checked the fuse behind the JVC radio itself and it is still good. what else can i do?
Old Nov 29, 2018 | 02:33 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 96 honda civic radio not working
check to see if you have power at the stock radio harness, +12VDC constant and +12VDC ACC
Old Nov 29, 2018 | 02:36 AM
b&j's Avatar
b&j
so how to do i do that? what if that doesn’t work? i checked both of my fuses a 7.5 under the hood which was blown so i put a 10 in and then the fuse box under my dash had a 20 in it when it only needed a 10 but that fuse wasn’t blown.
Old Nov 29, 2018 | 11:47 AM
NVturbo's Avatar
O.G. triple O.G.
multimeter
If there's not power on the appropriate wire, you likely have a blown fuse. Avoid putting in larger fuses than suggested.
Old Nov 29, 2018 | 11:54 AM
b&j's Avatar
b&j
well i had the 7.5 radio fuse under the hood was blown and i changed it but when i checked the radio clock fuse under dash it had a 20 but it only needed a 10 and that fuse was fine. i changed the 7.5 fuse with a 10
DEEPfrom1
Audio / Security / Video
11
Feb 8, 2009 10:03 AM
IP RACING
11
May 6, 2008 08:31 PM
skyvang2
May 28, 2007 03:21 PM
pinkspider
Oct 23, 2006 02:11 PM
ScottieA
Jan 23, 2006 12:01 PM
