Timing belt tensioner bolt broke off into block
Old Nov 27, 2018 | 10:37 AM
thewrai6th's Avatar
Default Timing belt tensioner bolt broke off into block
Bought the whole car for $500 with a blown HG. Was replacing the HG and the timing belt tensioner pulley bolt was stuck. It broke off in the engine block.
I'd drill it out, but I know I'll screw it up.
Anyone know a place near San Jose to get this fixed? I called a couple auto shops and they say they would screw it up too. Engine is in the back of my truck.
Old Nov 27, 2018 | 12:33 PM
Cupajoe's Avatar
Default Re: Timing belt tensioner bolt broke off into block
weld a nut to it. get it out. Or drill out bigger insert timesert in.
Old Dec 3, 2018 | 12:07 PM
hondamark35's Avatar
find a machine shop. doesn't even have to be an engine/auto machine shop. they should know what to do.
I'd do it for you but I'm kind of on the other side of the continent..
Old Dec 20, 2018 | 05:42 AM
B20vCRX's Avatar
Drill a little pilot hole in the center about 1/4' in. Take a torx bit and gently tap into the hole and ease it out. Usually works Everytime for me. Good luck
White91EF
Nov 1, 2022 07:26 PM
thewrai6th
Dec 3, 2018 12:34 PM
chope045
11
Aug 15, 2011 11:16 PM
methos713
May 5, 2008 12:29 AM
HOLDEM1981
Apr 12, 2005 03:34 PM
