i have 2003 honda accord ex with j30 and 6 speed shifter lsd
Im consider on placing a turbo on it....has 156 k i would pull the head port and polish and place a new ceramic head gasket resurface valves place new water pump and by high performance timing belt and place a high performance intake and place 50 lbs injectors ...any advice on what would give hp i already have 3 row radiators with one hayden fan and one flex lite fan which makes the car run cool . I also place a mega flow exhuast and took of cats i would also place 90 mm throttle body.....I was also consider placing a j 35 engine that i bought from jdm for another build this my personal car ....will j35 mount to 6 speed lsd tranny...im going to strip stock seats and place race seats i also im going take back seat and place batter in back seat and remove spare and place a fuel cell and drop gas tank ....would j35 mount to tranny if so ill bore and stroke and place high performace cam if its avable and puch rof and cylders and rooler rockers
- If you can tell us which J35 you have, such as J35A3, we can tell you whether they will bolt up.
- If you have a J35 which is incompatible with your tranny, the good news here is you can buy a new bell housing from Acura which will allow you to convert your tranny to the correct bolt pattern on the engine.
luther69
Oct 10, 2019 04:17 AM
