o2 sensor makes me sad
Old Nov 24, 2018 | 12:10 PM
clicky79's Avatar
5 Year Member
Default o2 sensor makes me sad
I've swapped a obd2 b18b1 into my civic, i replaced the o2 sensor with a 1 wire one (new out of box) and i keep getting a cel code for it, on my d series the o2 sensor was on the front of the manifold but on the b series its behind the motor right in front of the fire wall, could this new placement be causing my code, and what can i do to fix it? Please help, regards your local idiot!
Old Nov 24, 2018 | 06:16 PM
Marcos Barrios's Avatar
Default Re: o2 sensor makes me sad
the b18 thats in your car
is your wiring still obd0?
and the ecu thats controlling that wiring also obdo?
if your answer is yes to both those questions then a 1 wire o2 would work just fine
but if your answer was no to question 1 or 2 then no
if your wiring has been changed to obd1 or obd2 then you need a 4 wire o2 sensor.
and your going to have to wire it in
let me know if you want that wiring info
and goodluck
Old Nov 26, 2018 | 07:18 PM
muellersfan's Avatar
Post the ECU code.
Old Nov 26, 2018 | 07:29 PM
clicky79's Avatar
5 Year Member
Im getting a 1 flash code, it feels to last slightly longer than the other codes ive seen.
Old Nov 26, 2018 | 07:31 PM
^The IAT sensor is not plugged in.
But I was asking for the code written on the label stuck to your ECU.
Old Nov 28, 2018 | 08:20 PM
clicky79's Avatar
5 Year Member
Turned out i had the idle valve and its switched, im not throwing cel code anymore but it still idels at like 1200 rpm
v8killaz
Aug 4, 2009 06:06 PM
ef-hatchcrap
Jul 30, 2009 05:01 AM
kcrxxx
Aug 1, 2007 12:47 PM
jmac
Jun 12, 2004 10:11 AM
