Need Help ! B series
Old Nov 24, 2018 | 09:20 AM
Luis Sanz's Avatar
Default Need Help ! B series
So I swapped out my transmission fluid yesterday, replaced it with some pennzoil synchromesh because I had a small grind in third. I read on how to do it through the vehicle speed sensor (VSS). But now I'm having an issue with it going into gears. And it doesnt go into 5th. At all. And also do you fill it up to the top of the fill plug or the top of (VSS) Any help or suggestions., thank you.
Old Nov 24, 2018 | 09:24 AM
tony_2018's Avatar
Fish Twig
Default Re: Need Help ! B series
fill plug on level ground
Old Nov 24, 2018 | 10:31 AM
Luis Sanz's Avatar
Sounds good thank you. And does it matter how you put the (vss) assembly in?
TheoneTheycallVille
Mar 1, 2009 11:29 AM
turbociv910
Jan 26, 2009 09:17 PM
luv2boost
Aug 8, 2007 10:06 PM
demitrix
Feb 23, 2006 09:10 AM
4NOWJUSTADX
Nov 27, 2005 05:08 PM
