1998 . 2.3 vtec .P0300 and p0302
Old Nov 22, 2018 | 08:39 AM
Henry Tannor's Avatar
Default 1998 . 2.3 vtec .P0300 and p0302
I am getting hard cranking, especially when cold.When the car starts, it takes about 3 secs to smooth out and then it idles and drives fine until I shut it off for about an hr.After shutting it off for an hr, the cranks are not as hard as when I leave it overnight.
I have changed the plugs, wires, distributor w/cap and rotor.I even changed the main fuel pump relay.I am running out of ideas except the fuel pump and injectors.Any ideas?
p0300 and p0302.
Old Nov 23, 2018 | 10:10 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1998 . 2.3 vtec .P0300 and p0302
Valve adjustment done?
Verify fuel pressure.
Verify Batt voltage.
Old Nov 23, 2018 | 10:39 AM
p0300 and p0302.
Battery voltage is 14.1 on my scanner.How do I check fuel pressure when they dont give you a port to either connect a valve or screw on a pressure tester.Are you guys sure valve adjustment will casue this engine not to fire when cold?
Old Nov 23, 2018 | 10:41 AM
11.7 ohms on all the injectors.Pump squirts out fuel when ignition is on.It squirts for about 3 sec and stops.Seems normal.I just havnt checked the fuel pressure and I dont know how I will put a fitting there.I will check for 12volts at the injector harness and report back
Old Nov 23, 2018 | 10:54 AM
MAD_MIKE's Avatar
MM Gruppe B
That's running voltage.
What is the battery voltage when the car has been turned off for ~10mins?
What is the battery voltage during cranking?
Don't rely on the scanner for voltage testing, use a volt meter.
Old Nov 24, 2018 | 01:44 PM
typhoon's Avatar
I would think it's a fuel issue too. You might need to use a special tool to disconnect the fuel line quick release fitting, then you insert a pressure gauge in series with the line to measure pressure. You could test the spray pattern on the individual injectors too.
Old Nov 24, 2018 | 01:52 PM
The ohms are fine the injectors . I put the injectors back . If the spray pattern was bad on the injectors , I think it would constantly miss . It idles fine when started . I am also getting power to the injectors at the harness . I didn't check the voltage though . The pump is also spraying when the ignition is on .Although I didn't check the fuel pressure, I am leaning towards valve adjustment . The valve tick is constant. I will adjust the valves Monday
Thagoldenb
Jun 3, 2011 05:51 PM
Hondaisok
Oct 7, 2010 01:55 PM
go2sleep
May 4, 2007 07:19 PM
typer694
Jun 19, 2001 06:57 AM
