Looking for a little bit of help putting a parts list together for k20 head
Old Nov 17, 2018 | 02:55 PM
Dc4Colin's Avatar
Default Looking for a little bit of help putting a parts list together for k20 head
I do have most of the prts from my motor swap when my k20 blew up. I am just looking if someone cane give me a detailed parts lost of what i need to have a complete head. Thank you and any info will help.
Old Nov 17, 2018 | 03:12 PM
thisguyaves's Avatar
Default Re: Looking for a little bit of help putting a parts list together for k20 head
It would be more helpful if we knew which engine you have and waht parts are already in your possession. Otherwise I recommend acurapartsnow.com for their list and exploded view diagrams
Old Nov 17, 2018 | 04:09 PM
Dc4Colin's Avatar
I have a k24 engine in my rsx im looking to swap the k20 on in the spring. The parts i have is my head, rocker arm assembly, pretty mich everything for it to go back together the things i feel i am missing are valves, springs, retainers, etc.. I should have been more specific.
Old Nov 19, 2018 | 06:26 AM
For valves- ferrea, super tech, brian crower are all good brands. Flat faced bumps up compression just a touch.
For springs/retainers- Brian crower, super tech, skunk2... there are others out there, just read up on whether or not you want stainless steel vs titanium
Make sure you get the head decked and leveled. If you need valves, having a machine shop do a valve job and installation with head decking will cost about $400. Maybe port it too? Depends on what your goals are.
Assuming you have Kpro...
I'd also recommend a 50 degree VTC intake gear for wider tunability, and a good intake/exhaust manifold. While you're knee deep in the engine, it would probably be a good time to replace your timing chain and tensioner (recommend hybrid racing tensioner)
Old Nov 19, 2018 | 03:27 PM
Dc4Colin's Avatar
This is a great help thank you very much!
rohitb
Apr 16, 2010 07:39 AM
Nate047
10
Aug 10, 2007 12:37 PM
memorybox
Jun 23, 2006 11:35 AM
Wilky
Sep 13, 2004 02:18 PM
