B20 vtec oil in breather filter
Old Nov 14, 2018 | 02:58 PM
Sleepy216's Avatar
Default B20 vtec oil in breather filter
Reaching out for some clues as to why my friends swap is getting oil in the filter where the breather hose is located. He has a Frankenstein, b20 block with high compression Pistons and b16 head with high performance springs and retainers ported and polished at local machine shop. But I was looking today and noticed no pcv system maybe that's the issue? Any input is appreciated.
Old Nov 14, 2018 | 03:04 PM
muellersfan's Avatar
Default Re: B20 vtec oil in breather filter
Properly vent the crankcase and then go from there.
Old Nov 17, 2018 | 08:56 AM
TheShodan's Avatar
Moderator
Yes. That is the issue. You either need the pcv hookrd back up, or a proper catch can with a one-way check valve..
personally, it's easier to hook the pcv back up.
Old Nov 18, 2018 | 02:43 AM
tony_2018's Avatar
Fish Twig
These stupid valve cover breathers do you no good. I've had to correct a b18c5 before swapping it into the ek already.
joiv21
May 4, 2013 08:34 AM
DoyouVtec
Mar 23, 2005 08:20 AM
fabs
15
Feb 2, 2005 03:37 PM
