Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
ECM RESET CHECK ENGINE LIGHT 2008 HONDA ACCORD
Old Nov 10, 2018 | 09:14 AM
lemdog's Avatar
Default ECM RESET CHECK ENGINE LIGHT 2008 HONDA ACCORD
WAS WANTING TO RESET MY ECM ON MY 2008 HONDA ACCORD AND NOT SURE WHICH FUSE TO PULL OUT
Old Nov 13, 2018 | 05:00 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: ECM RESET CHECK ENGINE LIGHT 2008 HONDA ACCORD
An OBD-II compatible scan tool can reset error (trouble) code(s) depending on the type of trouble code and the scan tool.
The car stores various specific data in non-volatile memory even if there is no electrical power such as when the battery negative terminal or some fuses are disconnected. Only some system stored data is lost when the battery or some fuses are disconnected.
Even with the code(s) reset, the error messages will continue to show up if the problem/fault still exist or is detected. Some faults take more than one or more trips and/or conditions for them to trigger the Malfunction Indicator Lamp (aka Check Engine Light).
For some issues, if the problem gets corrected, the Check Engine Light go off on its own.
BettyBlue21
Jul 4, 2018 08:46 AM
pang07
Aug 6, 2013 05:11 PM
jtn625
Feb 9, 2008 09:34 AM
phillyjmb
Dec 22, 2005 08:57 AM
Jackalassassin78
Jun 25, 2003 08:44 AM
