K tuned shifter?
Old Nov 9, 2018 | 04:46 AM
BergRacing21's Avatar
Default K tuned shifter?
I normally don't like to make new threads considering most everything these days has been covered, but I've searched the past few days with very little luck. I've seen a few preludes that have ran the K tuned shifter and i can't seem to find any detail about it, or for that matter even find the pictures of the few i've seen.
-How hard is it to install?
-Pros/Cons?
-RSX cables over Prelude cables?
-Worth the money?
Reason I ask cause I've had a whole lot of trouble with shifting and the cables in my car (mishifts 2-3-2), and ALOT of people use the K tuned shifter. So wondering is it worth going that route? or just simply upgrading my cables or switching to RSX cables.
Old Nov 9, 2018 | 08:44 AM
snobordboy's Avatar
Moderator
Default Re: K tuned shifter?
Not sure that I have seen anyone here post about it, but I have seen some on FB. Pretty sure Blake had a car with the setup, or worked on one with it, maybe ask him?
Old Nov 12, 2018 | 08:59 PM
crazes's Avatar
Moderator
If my memory servers me right, My understanding that its literally plug and play. The only difference was something having to do with the bushings. Some people have taken and placed brass bushings to help out.
Old Nov 14, 2018 | 09:38 AM
See, that's what i was thinking. but i wasn't sure if there were any little tricks or tweaks you gotta make. I may just go ahead and do it, i imagine it shouldn't be too much trouble to figure out.
Old Dec 1, 2018 | 03:23 PM
PreludeJunkie91's Avatar
Post back up when you do it if it's just plug and play. Been wanting to run the k tuned setup with RSX cables when the build is finished.
Old Dec 3, 2018 | 12:03 PM
117's Avatar
117
It's not 100% plug and play, but can be installed in a 5Gen with a little bit of work. I'm using the OEM bracket on the trans, but KTuned makes an RSX cable specific bracket (have it, but have not installed it yet). With the OEM bracket, the cables do not stay parallel, but shifts fine.
Some pics here in a thread I have on another page: https://www.preludepower.com/forums/...=387538&page=7
Old Dec 4, 2018 | 04:51 AM
Thanks! that at least gives me a little help, nice to have a visual too.
SiouxLude
Feb 19, 2019 08:02 PM
92NoTeC
Honda Civic (2001 - 2005)
Nov 21, 2011 04:59 AM
thw_goalie
Oct 22, 2009 11:36 PM
gotrice16
Transmission & Drivetrain
Sep 2, 2009 02:53 PM
shllipperybert
16
Apr 4, 2007 09:45 AM
