Troubleshooting: Issues concerning AEM fuel rail O-rings
Old Nov 7, 2018 | 02:08 PM
MastaFlyMason's Avatar
Default Troubleshooting: Issues concerning AEM fuel rail O-rings
1990 CRX with b16a swap and AEM fuel rail. Precision 1000cc injectors. My issue is my injectors are really hard to get into the rail and when I get them in they end up taking a good piece off of the oring and then my rail leaks. I tried the OEM honda green injector o rings as well as the ones AEM provided with the rail. They seem to both be a little bit too thick. I've tried 4 different sets and every time I get a leak and I have to really force them in. What am I doing wrong?
Old Nov 7, 2018 | 07:19 PM
motoxxxman's Avatar
Default Re: Troubleshooting: Issues concerning AEM fuel rail O-rings
It's supposed to be a really tight fit.
Use a better lubricant on the o-rings
Old Nov 7, 2018 | 09:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You may be better off finding an aftermarket set of O-rings that have the appropriate inside diameter like the factory O-rings yet have a slightly narrower cross-section/outer diameter so you can insert them into the fuel rail a bit easier without damaging them. The last set I had trouble with, I used some out of a universal A/C O-ring kit I picked up at the auto parts store in place of the original injector O-rings or any of those included with the AEM fuel rail.
Old Nov 8, 2018 | 12:57 PM
Just a heads up to anyone else that may have this problem in the future - I found a big set of o rings that are fuel rated at harbor freight for $10. If anyone needs the size I can probably find it, but they fit right in no issues.
Local
Dec 27, 2012 04:30 PM
KdF
Jul 27, 2009 02:12 AM
redboost10
Feb 19, 2006 05:50 PM
bluebullet
Jan 7, 2004 08:44 AM
