vtec wiring 98 dx 5 speed
first post here. I have a 98 dx 5 speed non vtec project I been working on for a litte while now. grabbed a a1 vtec head from the junkyard and the correct ecu w/ the immobolizer. question I have is which plug and which pin do I need to put the wires into from the vtec sylenoid since Im not using a vtec engine harness
Someone else should check this but here ya go:
1. Get the honda shop manual... if I link to it the moderator will flag me.
2. You will need to wire the VTEC solenoid to pin B12 on the B connector of the ECU, pg 6-9, para. 26.
3. Wire from ECU C connector pin C10 to either of the two pins on the VTEC pressure switch, pg 6-7, para. 9.
4. Connect the other pressure switch pin to engine ground (technically its G101, which are the engine grounds located under the IAT sensor, ref 16, pg 22-15).
If I was doing this I would probably get the proper engine harness from a pick-a-part yard, but that's just me.
