Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic engine change help
Old Oct 29, 2018 | 07:15 AM
Dan Gray's Avatar
Default 04 civic engine change help
Engine going in
I have an 04 civic with a bad engine..... I picked up another engine and was getting ready to set it in and noticed a solenoid on the back of the engine that I guess is called a vtec solenoid???... the old engine does not have one.....so my question is if I put the new engine in without that solenoid plugged in will it hurt anything cause my car dosent have the plugs to plug it in.... the 2 engines look identical except that
Origanal engine out of the car
Old Oct 30, 2018 | 04:19 PM
thisguyaves's Avatar
Default Re: 04 civic engine change help
You basically will have the capability to run it, but not have vtec. Car will still run, though you can pick up a few ponies now with a vtec controller or the correct vec ECU/wiring harness. tuning might be a smidge different, but it should still work.
Walker Hall
Dec 1, 2016 01:44 PM
Topher75
May 28, 2013 05:09 AM
Rob C
Engine Management and Tuning
Aug 21, 2009 07:22 PM
ferngsr
Jul 26, 2005 02:14 PM
u_tal
Jul 14, 2004 10:20 PM
