Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 CR-V Power Window Issue
Old Oct 27, 2018 | 01:41 PM
Drew Hilton's Avatar
Default 2003 CR-V Power Window Issue
Hey Everyone,
First time posting. I'm fairly new to the whole car repair/maintenance world. The driver side power window won't go down on my 2003 CR-V. I realize this is a common issue. I tried the switch but that was not the problem. I have a new regulator/motor, and I was trying to replace the old one, but the window will not move down so I cannot access the two bolt that are on the track part of the regulator.
Does anyone know how to get the window to move down or where I should go from here?
Thanks for any help! And if this is not the right place to be posting, does anyone know where I might find help?
Old Oct 28, 2018 | 07:29 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2003 CR-V Power Window Issue
Remove the regulator mounting bolts from the door frame, then lift the regulator/glass up till the bolts that attach the regulator to the glass are aligned with the access holes in the door.
gqskrub
Apr 19, 2016 06:43 PM
acc0rdf22
Oct 8, 2009 12:17 PM
p0tential
Jun 21, 2007 04:40 AM
00ekcoupe
13
Aug 27, 2005 10:52 AM
Hondacrx628
Nov 13, 2004 01:23 PM
