Honda CR-V & Element 2WD & 4WD Element & CR-V
Are all 03-11 Element suspension parts compatible with 02-06 CRV 4wd?
Old Oct 19, 2018 | 03:39 PM
HondaGuy2020's Avatar
Default Are all 03-11 Element suspension parts compatible with 02-06 CRV 4wd?
I'm going to be rebuilding the suspension on my 2006 CR-V 4wd. I can't find very many aftermarket parts for it. I haven't been able to get a definite answer anywhere so I've decided to come here and ask this very basic question... does stuff like rear upp arms, rear lower arms, front upper arms, front lower arms, tie rods, toe rods , coilovers etc all compatible and does the 4wd part play a major factor with compatibility? basically im limitted to online orders and a lot of places dont even ship to my state. My suspension is worn out and i might as well lift it if i have to replace suspension anyways amirite
Old Oct 22, 2018 | 08:31 AM
Occidentalis's Avatar
Default Re: Are all 03-11 Element suspension parts compatible with 02-06 CRV 4wd?
Check the OEM part numbers between the element and the CRV you have, paying attention also to where it was built. If they are the same between the two, they are the same parts. Most of it will fit. Look at the CRV performance thread. You shouldn't have to buy many element parts. When I redid the suspension, nothing was labeled element, only cross labeled. https://honda-tech.com/forums/honda-...hread-3043505/
Dipsett
Suspension & Brakes
10
May 6, 2013 10:49 AM
Yog8511
Mar 17, 2007 07:33 PM
cam3ron88
Feb 23, 2007 04:32 AM
CooBlueDAB
Oct 8, 2006 04:52 AM
