2006 Honda Accord V6, 72k miles, timing belt, water pump, tensioner
I have a 2006 Accord V6, approaching 72k miles. Obviously the car hasn't been driven much, but its been aging. Car is running good, except for chirping/whistling sound near the tensioner.
As preventative maintenance, do you recommend, I get any of the following (all of these have never been done before):
1. Timing belt
2. New water pump
3. Tensioner pully replacement
If I get all three of these done at the same time, will there be any labor savings?
What is a good price range for getting all three of these done -- at a local independent, trustworthy mechanic?
Currently, our Honda dealer is running a special for Timing Belt replacement for $400. I'm wondering how many additional hours on top of Timing Belt, does replacing the water pump and tensioner pully, require.
Anything else I should be doing while they are going in there?
1. Timing belt
2. New water pump
1. Timing belt
2. New water pump
1. Timing belt
2. New water pump
Repair Pal is fairly reliable for average prices in your area.
That price is outstanding, shouldn't be more than $300 for the remaining components. Have both cam and crankshaft seals done as well. ASK for the old seals during the transaction. . Dealer mechanics have a bad habit of not replacing them and there is no way for you to check unless you tear into the vehicle yourself.
jttca
Jun 11, 2011 04:11 AM
