Rota Slipstreams on CRX: what size?
Old Oct 13, 2018 | 07:26 PM
400whp's Avatar
Default Rota Slipstreams on CRX: what size?
I want to buy Rota Slipstreams for my CRX. I'm getting 15". Should I get 15x6.5 or 15x7?
Old Oct 14, 2018 | 06:53 PM
acmoc's Avatar
Default Re: Rota Slipstreams on CRX: what size?
What is the offset on them? 15x6.5 needs a 35 mm offset.
15x7 needs at least a 38 offset.You don't want them to stick out too much but not be dished in like stock wheels.
Also depends on tire size you want.
I use 195/50/15 on 15x7 +38
The 195/50 is lighter than the 205/50 and has a smaller stiffer sidewall. Yet the stretch of being on a 15x7 gives it basically the same width of the 205.
But if you want to run 205/50, then the 15x7 really is the only choice. As it will fit a 15x6.5, but it will baloon over the lip and look odd.
In this case, you need 15x7+41 offset though.You can get 195/50/15 latter and add a 3 mm spacer though.
Also depends on the weight of the wheels.
I recommend the 15x7. With 195 50 15 it will keep the car lower too.
Old Oct 14, 2018 | 09:37 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
15x7
Old Oct 16, 2018 | 09:53 AM
tommycrx's Avatar
I've seen 15 x7 in +35 work, as do many +36's. Depends on the particular rim, but you can go lower than +38 and still not need spacers; I do agree that all else being equal, 7's make more sense than 6.5's, unless you're sold on a particular rim that isn't available in 7's (Mugen RNRs, for example). Good luck with the purchase.
WeakSauceEJ8
Mar 25, 2011 08:41 AM
manyakiexpi
Feb 27, 2006 09:59 PM
Tim_Robbinz
Jul 21, 2005 01:06 PM
HUBB
May 4, 2004 09:51 AM
excoupe97
Mar 27, 2004 05:42 AM
