1996 Accord 4cyl code P0501
Old Oct 11, 2018 | 05:04 PM
Joel Diaz's Avatar
Default 1996 Accord 4cyl code P0501
Hello, I need help solving this problem. It says it's the vehicle speed sensor but I don't know which is it. There is a silver and black one on top of the transmission and a black one on the side. If I search online both sensors appear but I don't know which I have to replace. Both are connected, haven't checked for power going in.
Also, the speedometer doesn't work neither does the odometer. Please help.
1996 Honda Accord LX 4cyl SOHC Automatic
Old Oct 12, 2018 | 01:14 AM
KellzAccord's Avatar
Default Re: 1996 Accord 4cyl code P0501
If your speedo isn’t working you got a bad VSS or no power getting to it. But it’s on top of tranny. It’s the only one that has a plug. Should be 3 wires. 1 bolt(10mm) will take the hole VSS.
Old Oct 12, 2018 | 12:45 PM
Joel Diaz's Avatar
Ok, but there is this other black speed sensor, what's that for? The top one is for the odometer right?
01hon-duh-eh-chord
Jun 11, 2013 04:45 AM
Navy_Engineer
May 2, 2013 09:21 PM
blakenshake8
Feb 9, 2011 06:04 PM
thisiskev
Jun 8, 2010 01:13 AM
00MRSi
Nov 19, 2002 01:34 PM
