Speed Sensor....?
Old Feb 7, 2007 | 10:20 AM
01hon-duh-eh-chord's Avatar
Default Speed Sensor....?
Got failed at emissions and was told the speed sensor is not working. Speedometer is not working now, but other dash gauges seem fine. Odometer is not working either. I have googled to get more info on this and how to replace this part, but it has been rather difficult. Any help on this? It may seem that the 2001 Honda Accord has no speed sensor, could that be true or is it inclusive with the cluster?
Old Feb 7, 2007 | 11:10 AM
TheMuffinMan's Avatar
He knows where you live!
most like it is just a bad VSS - if it's like my car (dunno if they changed it) it's on the transmission unbolt the old and replace with a new one
Old Feb 7, 2007 | 12:22 PM
CARMandP's Avatar
Any codes in the computer? VSS will set a code of some kind.
Old Feb 7, 2007 | 12:26 PM
Default Re: (TheMuffinMan)
Thanks for the post, but I am not finding a vss for a 2001 honda accord available?? Could this be because it doesn't exist? If not, what could have caused this problem?
HELP!
Old Feb 7, 2007 | 12:27 PM
Default Re: (CARMandP)
I need to run the diag. test. I can re-post, but the emission result says...hang on let me get that and re-post.
Old Feb 7, 2007 | 12:31 PM
Default Re: (01hon-duh-eh-chord)
The emission result posted a P0500. Not sure if that syncs with the standard diag testers...but any help would be greatly appreciated.
Old Feb 7, 2007 | 01:43 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01hon-duh-eh-chord &raquo;</TD></TR><TR><TD CLASS="quote">The emission result posted a P0500. Not sure if that syncs with the standard diag testers...but any help would be greatly appreciated.
that is just freaking amazing ! ! ! P0500 is a VSS code, and a speedo won't work with a bad VSS. Oh man all the cosmic tumblers have clicked into place.
The VSS is located on top of the differential housing above the inner CV joints. 3 wire connector is attached to it.
I'd upload a pic for ya but this forum does not support anything like that.
Old Feb 9, 2007 | 10:35 AM
Default Re: (hondadude)
Thanks. I will look for this part.
Regards.
Old Nov 4, 2009 | 01:13 PM
billsmith8's Avatar
New User
Default Re: Speed Sensor....?
I had this same problem on my Accord (2000 LX Coup, MT), replaced the VSS (very simple, one bolt and one plug, 10 min.) Drove it and it worked fine. Reset the check engine light according to directions by pulling clock backup fuse for 10 min. I drove 4 miles and the speedometer quit again, check engine light is back on and it is once again giving the ecu code P0500 (17)VSS. Any ideas what might cause this?
Thanks in advance for your help,
Old Nov 4, 2009 | 01:23 PM
Did you buy an eBay VSS?
Old Jul 28, 2010 | 01:37 PM
Frankie324's Avatar
I had this same thing happen. No ebay vss. It worked for like a few miles now it quit again, CODE P0500. Fuse is good, any ideas??? i'm lost. Thanks. I have a 2000 F22b1, 5 Speed. Motor is stock, no aftermarket parts.
Old Jul 28, 2010 | 01:46 PM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/vss.html
Old Jun 10, 2013 | 01:12 PM
jnotaro's Avatar
Ok I read this thread and am curious, I have an 08 Integra w/1.8, standard shift. I get the P0500 speed sensor code but everything is working fine, Speedo, odometer etc. I've cleared it and it comes back after a mile or so. Any idea's?
If something didn't work I'd understand it but no problems...
Old Jun 10, 2013 | 11:29 PM
holmesnmanny's Avatar
I'm guessing you have a manual.
If you have cruise control see if you can get cruise control to work.
Old Jun 11, 2013 | 04:45 AM
jnotaro's Avatar
Yes, cruise control works as well, frankly I'm baffled at this code as the Speedo, Odometer and cruise control all work. Any ideas would be great.
Rat Rod
Nov 18, 2010 04:02 PM
aziaticvang
Jan 13, 2008 06:35 PM
refman102
Oct 25, 2007 05:24 AM
uEDarkShadow
Jun 22, 2006 08:23 PM
brutus101
Sep 9, 2005 06:08 AM
